Cinsky nabijaci kabel 3x16A 11kW
    • 337
    Dobry den - pikorecenzia:
    Kupil som tento kabel 24.11. z CZ skladu:
    Cena bola 227 eur a prisiel z DE 30.11. kurierom, ziadnu dan ani clo som nedoplacal.
    Dlzka aj so zapojenou redukciou na 230V je asi o 20cm kratsia ako origo dodany kabel k Citigo.
    V baleni bol proti popisu navyse kratky kabel s 3F samicou na jednej strane a s nicim na druhej strane, neviem, ci sa jednalo o chybu.
    Da sa prepinat nabijaci prud 8/10/13/16A. Druhym tlacidlom sa ma dat nastavit oneskorene nabijanie.
    Zatial nabijam len 16A 1F, viacfazove nabijanie momentalne neviem ani vyskusat. Funguje to.
    Na displeji ukazuje viacero informacii: napatie, aktualny nabijaci prud a vykon; cas a spotrebu.
    Teplota je nejak mimo, pri 0 oC vonku a dlhom nepouzivani po zapnuti zacal ukazovat 18 oC.
    Skoda, ze nema pamat na nameranu spotrebu.
    3F zastrcka je ta mensia, 16A, 5kolik. Vodice maju prierez 2.5 mm2. Kabel je velmi hruby a gumeny.
    Malo by to byt vodotesne, IP 44 zasuvky / IP 55 "riadiaca jednotka".
    Prudovy chranic treba dokupit zvlast, napr. http://www.evexpert.sk/c/prislusenst...chrana-obvodov
    Ak by Vas zaujimalo nieco konkretne, dajte vediet.
    Click image for larger version  Name:	image_6631.jpg Views:	371 Size:	59.6 KB ID:	64878Click image for larger version  Name:	image_6632.jpg Views:	276 Size:	116.0 KB ID:	64879
    Click image for larger version  Name:	image_6633.jpg Views:	275 Size:	119.4 KB ID:	64880Click image for larger version  Name:	image_6634.jpg Views:	267 Size:	169.6 KB ID:	64881
    Click image for larger version  Name:	image_6635.jpg Views:	260 Size:	210.3 KB ID:	64882Click image for larger version  Name:	image_6636.jpg Views:	268 Size:	53.5 KB ID:	64883
    Click image for larger version  Name:	image_6637.jpg Views:	267 Size:	68.2 KB ID:	64884Click image for larger version  Name:	image_6638.jpg Views:	273 Size:	168.2 KB ID:	64885
    Click image for larger version  Name:	image_6639.jpg Views:	269 Size:	148.6 KB ID:	64886Click image for larger version  Name:	image_6640.jpg Views:	261 Size:	76.7 KB ID:	64887
    Click image for larger version  Name:	image_6641.jpg Views:	265 Size:	61.5 KB ID:	64888Click image for larger version  Name:	image_6642.jpg Views:	264 Size:	29.7 KB ID:	64889
    Naposledy upravené denial; 03-12-2020, 08:28.
    Aka je celkova dlzka kabla?
    Bolo by zaujimave otestovat ako moc sa hreje ta elektronika ked ju zapnes na plnych 16A. Teraz v zime to nie je uplne ono ale daj vediet. V idelanom pripade ostane to puzdro normlane studene (tak by to malo byt).
      Tiez ma zaujima hlavne ta celkova dlzka
      • Sly
        Sly
        • May 2020
        • 21
        Ahoj. Mňa by zaujímalo nabíjanie cez tú klasickú Schuko zásuvku, nerobí to žiaden problém keďže je to cez tú redukciu? Vidno fakt reálny nabíjací progres proti klasickej dodávanej 10A nabíjačke? Myslím tým skrátenie nabíjania. Hneď by som to zobral na "nočné" nabíjanie. A potom by som mal aspoň väčší dôvod dať si konečne vonku na dom 400V zásuvku. Dikes
        Edit: no tak to vyzerá že CZ warehouse is out of stock :-(
        Naposledy upravené Sly; 03-12-2020, 10:48.
          Ta redukcia ziaden problem robit nebude, lebo tie kontakty v 3 fazovej zasuvka su na to dimenzovane. Co moze byt problem je ale tvoja zasuvka v dome. Velka vacsina z nich nie je veru stavana na trvaly odber 16A. Ja som skoncil s jednou roztavenou (ta bola v stene) a musel som to urobit tak, ze som dal krabicu na stenu a do nej som dal kvalitnu zasuvku (nejlepsie s keramickym stredom) a este som navrtal dierky na spodu a navrchu pre vetranie.
          Druha moznost je zobrat zasuvku s montazou na povrch, napr tuto:
          To je asi jednoduchsie ako bastlit zapustenu zasuvku do krabice.
        • Sly
          Sly komentoval
          Jiri GrandPa Ja mám vonku jednu IP zásuvku, ale je z plastu :-( Síce je na nej 16A, no určite nie na trvalý odber. Zatiaľ nabíjam len priloženou 10A nabijačkou
          Tak si to proste otestujes a ak sa to bude moc hriat nastavis 13A. Alebo ju vymenis za kvalitnejsiu ked musis mat tych 16A. Kazdopadne to netreba podcenovat lebo mozes vyhoriet. Istic to nevypne lebo prud je v jeho medziach.
        Potrebujem radu, mam prenosnu nabijacku na 3x380 wallbox, ale mali skladom iba verziu s 5 M kablom , keby som chcel predlzit o dalšie 4 M , je nejaka redukcia na koncovku aby som vedel nadpojit kabel? Tuto nabijacku používam vid. link. Dakujem.
          Musíš to nadpojiť na tej strane CEE.
          Dajú sa kúpiť 3 fázové predlžovanie káble 3x400V.
          Takéto niečo.
          Naposledy upravené Jiri GrandPa; 06-12-2020, 20:20.
          Jirko, dufam, ze sa nebude chalan drzat linku od teba, tam je kabel len 1.5ka
        • kayle
          kayle komentoval
          Hmm... 1,5 na 16A to je fakt hobby, alebo pre Sibír, aby to uchladilo.
          Ako píše Dango, pozor to aký drôt tam je, lebo 1,5 je tak 10A max. (chvíľkovo vydrží aj 16A, ale tu by som nešetril), mal by mať 2,5 aby to bolo vyhovujúce pre 16A.
          Naposledy upravené kayle; 04-12-2020, 12:47.
          dango - ty vole máš pravdu. Ja som to neštudoval dal som prvý čo mi vyplul Google. By ma vo sne nenapadlo že sa taký kábel vôbec vyrába. Opravil som na správny typ.
        Super dik za info da sa to riešiť aj takto som myslel že predlzim kábel na konci ktorý dávam do auta ale aj toto je riešenie.
