Priprava domu na elektromobil
    • 1362
    #16
    takéto niečo (je to na tuya zásuvky z aliexpress, tých mám plno):
    import requests
    import json
    from bs4 import BeautifulSoup
    import tinytuya
    import time
    device_id = "........................"
    local_key = "......................."
    ip_address="192.168...."
    d = tinytuya.OutletDevice(device_id, ip_address, local_key)
    d.set_version(3.3)
    data = d.status()
    zapnute=data['dps']['1']
    # Show status and state of first controlled switch on device
    #print('Dictionary %r' % data)
    #print(data)
    url = "http://192.168.5.108"
    page = requests.get(url)
    soup = BeautifulSoup(page.content, "html.parser")
    for tr in soup.find_all('tr'):
    th = tr.find('th')
    if th and th.text.strip() == 'L1:':
    td = tr.find('td')
    if td:
    l1_value = td.text.strip().split(' ')[0]
    if th and th.text.strip() == 'L2:':
    td = tr.find('td')
    if td:
    l2_value = td.text.strip().split(' ')[0]
    if th and th.text.strip() == 'L3:':
    td = tr.find('td')
    if td:
    l3_value = td.text.strip().split(' ')[0]
    if th and th.text.strip() == 'Charge Current:':
    td = tr.find('td')
    if td:
    nabijanie = td.text.strip().split(' ')[0]
    l1= float(l1_value[:-1].replace(" ", ""))
    l2= float(l2_value[:-1].replace(" ", ""))
    l3= float(l2_value[:-1].replace(" ", ""))
    nabija = float(nabijanie[:-1].replace(" ", ""))
    prud=l1+l2+l3
    print(prud,zapnute,nabija)
    if zapnute == True and (prud>0 or time.localtime()[3]<9 or time.localtime()[3]>18):
    d.turn_off()
    print("Vypínam ohrev vody")
    if zapnute == False and (prud<-10 or nabija>10) and time.localtime()[3]>8 and time.localtime()[3]<19:
    d.turn_on()
    print("Zapínam ohrev vody")
      • 183
      #17
      Daj vedieť či ti ho poslali. Silno som rozmýšľal že ho zoberiem keď som to našiel.
      Dosiel
        To má volakto šťastie.
        Tentokrat sa zadarilo musel to byt naozaj posledny kus, dakujem este raz za tip Konal som rychlo
