OC Idea, Ilava
  • Ejoin EU
    • 267
    OC Idea, Ilava
    ejoin nabíjacia stanica pred OC Idea, Ilava
    Ľudovíta Štúra 2000/90 OC IDEA, 019 01 Ilava
    Pred čerpacou stanicou Ilava, pri OC Idea v Ilave
    DC: do 60 kW, 1xCHAdeMO, 1xCCS2
    GPS: 49.007215, 18.257493
    Platba: podľa cenníka
    Ováracia doba: Nonstop
    Prevádzkovateľ: ejoin
    Email: info@ejoin.eu
    Tel: +421 424 111 111
    Click image for larger version  Name:	WhatsApp Image 2020-11-19 at 13.14.05 (1).jpeg Views:	583 Size:	105.9 KB ID:	64161
    Naposledy upravené Juro; 28-09-2022, 23:37.
    • 698
    Tato uz aj bude fungovat?
      • Sep 2019
      • 104
      Neviete to niekto zistiť, či už funguje? Potrebujem budúci týždeň 2 x nabiť..
        Veď skús ty a ak nie tak ufc na slovnaftke vraj funguje a máš ho o 300m bližšie k dialnici. Ináč super, 2xDC behom týždňa vykvitlo v Ilave.
        V pondelok idem tak vyskúšam..
      • Mar 2018
      • 74
      Dnes som bol skusit. CHAdeMO pisalo "Equipment Failure", CCS pisalo ze je ready. Ale spustit nabijanie som nedokazal, kedze ma pytalo zadat ciselny kod (ktory uz davno nemam, kedze od zalozenia konta uz davno ubehol prvy mesiac). RFID kartu mi nechcelo vziat, sice to "pipalo", ale nic sa neudialo, stale chcelo len ten kod. Skusil som dat nudzovy reset, ale po nom uz aj CCS zahlasilo "Equipment Failure", takze obidva konektory nakoniec ostali nefunkcne.
      Vedlajsi Slovnaft UFC isiel v pohode.
      • Cédric Escher
        • Aug 2020
        • 11
        HI, I tested the CCS on Saturday 21.11.2020. It worked well with the e-join card. I only got ca. 35kw, but my battery was cold.
          Hi, I tried yesterday but it wouldn't accept my e-join card - it was always asking me to enter PIN instead. Then I tried to emergency-reset the connector but immediately after that action the "Equipment Failure" message appeared for both CCS and CHAdeMO connectors. Hopefully they fix it soon.
          EV_Future Maybe this is only a problem of Kia e-Niro. I got same errors on ejoin 60kW Banska Bystrica and never charged successfully my e-Niro there.
        • janulo
          janulo komentoval
          I wasn’t able to charge my BMW i3, this was the first DC where I had problem (but this was my first eJoin DC at all).
        • Sep 2019
        • 104
        Tak som bol dnes skúsiť CCS. Najskôr sa nabíjačka nedala spustiť, ani na štvrtý krát, tak som volal na support. Veľmi milá pani sa mi snažila pomôcť na piaty krát a tretie odpojenie auta sa mi podarilo dostať na stránku kde sa zadáva PIN kód, ktorý mi poskytli pri registrácii, kým mi príde karta. Ten však nefungoval. Nakoniec som s pomocou supportu nabil ale som zistil že celý problém bude asi v displeji nabíjačky. Touch screen veľmi zle reaguje na dotyk, zaberie vždy na tretí - štvrtý krát. Potom už prebiehalo nabíjanie v pohode. Páni z ejoin by mali zapracovať na vylepšení ovládania displeja, prípadne ho opraviť. Inak za mňa super nabíjačka a aj dobre umiestnená.. Nabíjanie išlo do 49kW..
        Naposledy upravené Roman-ba; 23-11-2020, 17:37.
        • Ľuboš Geleta
          • 503
          • lubos98970
          Ahojte je tam tá nabíjačka a funguje správne? Hlavne CCS
          • Cédric Escher
            Cédric Escher komentoval
            Yes, I charged there on CCS on 23. November. Alternatively there is a CCS 75kW at Slovnaft 250 meters from eJoin.
            (google translate)
            Áno, účtoval som tam na CCS 23. novembra. Alternatívne existuje CCS 75kW v Slovnafte 250 metrov od eJoin.
            Áno, len dotykový displej má problémy, zaberie tak na 3-4 raz.
            Ale Slovnaft má UFC ako v Senci pár sto metrov od diaľnice, načo chodiť na eJoin ak je voľná ?
          • 1romeo1
            1romeo1 komentoval
            Miroslav Rojko Ako sa na Slovnafte platí a aká je cena a rýchlosť, lebo pod tou stanicou nieje možné fórum???
            1romeo1 bohuzialod prazdnin draho
            https://teslaclub.sk/node/42202?p=73375#post73375
          • 1romeo1
            1romeo1 komentoval
            Miroslav Rojko fuuha no ak si takto predstavujú elektromobilitu za 45centov/kWh, tak to teraz ked jazdím na LPG tak jazdím o polovicu lacnejšie. ZSE,green way a Slovnaft ak tu spravia monopol a poberú aj tie výzvy čo pojdu z plánu obnovy tak sme v riti a to drahej.
            1romeo1 neboj VW Ti da k ID.4 nabijaciu karticku, potom sa Ti poradie nevyhodnosti nabijania trocha pomeni
          • 1romeo1
            1romeo1 komentoval
            Miroslav Rojko myslíš drahe Ionity? Ak nebudem platiť paušál tak 75centov/kwh???
            Prave naopak, Ionity bude vyhodnejsie ale vsetko ostatne drahe. Kto nabija aspon dvakrat mesacne, najlepsi bude Greenway MAX (prvych 100 kWh po 25 centov a potom po 29). eJoin 23c pre ich nehoraznu neriesenu nespolahlivost neratam do cenoveho porovnania.
          • 1romeo1
            1romeo1 komentoval
            Miroslav Rojko "bude"??? ako to myslíš ved oni majú teraz najlacnejšiu cenu 30 centov/kWh pri paušáli mesačnom 17,49€. Alebo sa mýlim a niečo je nové, alebo bude? Ja budem doma nabíjať zadarmo zo slnka, ja len semtam ak pojdem Blava alebo Košice tak budem potrebovať čosik dotlačiť z rýchlonabíjačky, takže mne sa nebude oplatiť platiť paušál.
            VW sledujem okrajovo ale zachytil som, že prvý rok ten paušál neplatíš a teda Ionity je po 30c a to je menej ako iné aj pomalé 50kWh nabíjačky. Alebo Ti pove dali, že máš prvý rok platiť ? Nezaujíma má to tak aby som to hľadal ale ak to tak už nie je, tak m prosím oprav.
          • 1romeo1
            1romeo1 komentoval
            opýtam sa suseda predajcu, ale ajtak kde na SVK je Ionity? A kým ich postavia tak rok prejde. Inak ked si tak spočítaš tak ked oni nakúpia elektrinu za 10-12centov a predávajúju za 45centov až 55 centov(next) tak to je priam výpalnícka marža a podľa cien aj na západe tak to nevyzerá nejak ružovo s tou cenou na DC nabíjačkách. Mne by inak kľudne stačilo aj do 50kW DC a tých má byť z plánu obnovy 500ks a to je okolo 7ks na okres. Myslíš, že vznikne viac nových provaiderov a ceny budú klesať?
          • Peter A
            Peter A komentoval
            1romeo1 od VW je to WE Charge bez pausalu 55 centov/kwh na Ionity
            Naposledy upravené Peter A; 21-08-2021, 19:34.
          • 1romeo1
            1romeo1 komentoval
            Miroslav Rojko tak tu je aktuálny cenník pre majiteľa ID4, žiadna sláva. Bez paušálu ako Peter A písal ale len rok zdarma. Len rok akcia https://www.vw.sk/technologie-a-konektivita/we-charge
            Naposledy upravené 1romeo1; 26-08-2021, 17:41.
            Sranda, novemu majitelovo daju rok zlavu zo 17,49 na 9,73€ mesacne za najvyssi pausal a Ionity za 30 centov. Nejaky ich ekonom im vyratal, ze kupenim auta im zakaznik stoji na zlavu 7,76€ mesacne na rok, keby mu to dali rok zdarma ako k Enyaqu, uz by boli vysoko stratovi a to si VW nemoze dovolit.
          • 1romeo1
            1romeo1 komentoval
            kamarát mi pisal že má ZSE Flat za 69€ a má tam 400kWh čiže 17 centovkWh to je ešte výhodnejšie ako greenway. A ZSE má aj roaming ako to funguje v zahraničí a spadá to do predplatných kWh??? len on jazdí hlava nehlava.
            To ano ale minut 400kWh je uz trocha vela jazdenia po DC, pisal si ze vacsinou budes nabijat doma ako aj vacsina EV-ckarov, preto sa GW s ich 100kW (2 nabitia do 80%) javi ako idealne na obcasne dlhsie trasy nad dojazd auta.
            Ak nabijas cisto doma z FVE a dlhsie trasy s potrebou nabijania ides len “sem-tam” ako hovoris, tak ta stale vyjde najlacnejsie akykolvek gratis pausal. Aj keby si mal platit 50c/kWh tak na tych par vyjazdov rocne su to podla mna male polozky, a nemusis sa nikde viazat ani mesacne platit. Pokial pravidelne necestujes tak by som nejake cenniky ani neriesil. Usporu budes mat tak ci tak uz len z toho titulu, ze vacsinu najazdu ti bude dotovat slnko. A stale sa daju najst nejake gratis nabijacky ak sa postasti 🤷‍♂️
        • janulo
          • 46
          Dnes som to s i3kou nerozbehal, a to som skúšal niekoľko krát. Podobne ako v predchádzajúcich príspevkoch - karta pípla ale nič z toho. Auto aj bliklo na modro na sekundu ako keby sa začalo nabíjanie, ale hneď to padlo a konektor odomklo.
          • janulo
            janulo komentoval
            Dnes to rovnako nefungovalo, skúšal som minimálne 3x. Zišlo by sa to už možno aj opraviť
            V ejoine majú síce fungujúce call centrum ale to je asi tak všetko. Ja som s nimi riešil problém s touto nabíjačkou ešte v novembri ale čítam tu že sa nič nezlepšilo. Je to škoda a zároveň to vrhá zlé svetlo na tútu spoločnosť a jej nabíjačky.
        • Bruno75
          • Jul 2021
          Dnes som sa zastavil aby som sa docucol ale nepodarilo sa mi rozbehnut CCS ani po 3 pokusoch s kartou, vsetko vypadá ako by sa malo onedlho spustit ale nic sa nedeje, nahodi tabulku s nabijacimu parametrami ale nic sa nedeje, všade nula. Po 10 minutách som to vzdal, nemal som toľko času sa s tým trápiť a volať na hot line. Škoda aspoň keby tam bola hneď aj AC (viem, tá je o pár sto metrov ďalej).
          • MilanR
            Vyskúšané 30.7.2021. Nabíjačka funkčná a spustenie bez problémov. AC stĺpiky kúsok odtiaľ pred Billou sú ale nefunkčné, jeden prelepený kartónom a bez kábla, druhý po pripojení kábla vôbec nereagoval.
Meno:	image_7529.jpg
Videní:	943
Veľkosť:181,8 KB
            • 1romeo1
              1romeo1 komentoval
              MilanR kolko eur sa platí navyše ak by som si chcel dať také ŠPZ ako ty"s menom", ale + jednu navyše na stojan na bicykle. čiže tri kusy?
            • MilanR
              MilanR komentoval
              331€ sú dve custom značky + 16,5€ by malo byť vydanie tretej EČV na stojan na bicykle
            • 1romeo1
              1romeo1 komentoval
              aj ed je tá tretia Customs tieš? Nestojí jiež okolo 166€???
              Ja len, že tretia značka sa na želanie nedá vybaviť.. 😒😁
            • 1romeo1
              1romeo1 komentoval
              Roman-ba teda ak chcem používať cyklo nosič tak jedine obyčajné značky 3ks je možné kúpiť?
              1romeo1 Alebo prekladat znacku z auta na nosic? Ci to sa nemoze?
            • 1romeo1
              1romeo1 komentoval
              ževraj nie
              Samozrejme, môžeš zadnú značku preložiť na nosič. Ide o to, aby bola zozadu riadne viditeľná. Nie je povinnosť mať tretiu značku na nosiči. Je to len pre pohodlnosť tú tretiu značku mať.
            • Sep 2019
            • 104
            1romeo1 tak tak, ak chceš tri značky, nemôžu byť na želanie. Alebo na želanie a zadnú prekladať.
            • 1romeo1
              1romeo1 komentoval
              dik, asi si objednám tri obyčajné
          • Rasto6
            • 45
            Práve nefunkčné, nedá sa rozbehnúť kartou a cez hotline, tiež nie, napriek tomu, že display píše ready.
            • 1romeo1
              • 48
              Ide tá DC nabíjačka aktuálne?
              • janulo
                janulo komentoval
                Ja som tam nabíjal v nedeľu, aj týždeň predtým a v pohode. Prípadne odporúčam vo všeobecnosti pozrieť aj PlugShare, či sa tam niekto checkol nedávno.
              • Peto02
                Peto02 komentoval
                Dnes som sa chcel nabit a nedala sa spustit, pani na Hotline mi povedala ze je nefunkcna... tak som isiel aspon k Bille na AC.
            • Ejoin EU
              • 267
              Dobrý deň, na tejto lokalite prišlo k výmene prvej generácie DC stanice za druhú generáciu. Presunutá sem bola z lokality Žilina Todos.
              Dostupný je plný výkon 60 kW, CCS2 a CHAdeMO konektor. Len 2-3 minúty z diaľnice.
                Môžem sa spýtať, čo bude s lokalitou Žilina Todos po presunutí nabíjačky?
              • Ejoin EU
                Ejoin EU komentoval
                Plánujeme rekonštrukciu danej lokality.
