Model X - videá produkčnej verzie
    • 2001
    #16
    Model X 17" display
      #17
      Dalsie obsahovo aj technicky kvalitne (az na mikrofon) video modelu X, toto je prva cast, dalsie budu zrejma nasledovat
      Radsej klikajte sem: to iste, len lepsi zvuk: https://www.youtube.com/watch?v=TKDd_Z-JxIY
      Naposledy upravené jux; 28-01-2016, 17:43. Dôvod: Linka s lepsim zvukom
        • Aug 2015
        • 69
        #18
        Tu je fun video, ako sa sucasne otvaraju predne dvere (aj spolujazdcove Stano Kurek ) a Falcon Wing Doors (FWD).
        Nedavno totiz boli obavy, ze sa nedaju naraz otvarat predne dvere a FWD, lebo sa navzajom dotknu. Tesla vydala stanovisko, ze to mozne je. S varovanim, ze medzi nich netreba dat ruku, ked su v pohybe blizko pri zatvorenej pozicii. V podstate, ze to je podobne, ako si privriet ruku do obycajnych dveri. Boli to 😉
        (supplied by technical team) Front door and falcon door are perfectly fine to open at the same time as the opening arc of the front door is tangent to the arc of the falcon door. The only thing to be aware of is that given the close clearance between the doors, one should be careful not to place one's hand on the outside edge of a closed or nearly closed front door while the falcon door is in motion and also nearing the closed position. Basic due-care that one would apply to similarly-sensitive areas of a conventional door near the hinge point or when nearly closed.
        • MravecSK
          • 214
          #19
          Pisu ze nie je mozne aby sa dotkli dvere, len zeby sa tam mohol niekto privriet pri urcitom uhle otvorenych prednych dveri a zatvarajucich/otvarajucich sa FWD Na TMC zalozili vlakno, kde ludia davaju otazky a majiteli modelu X ich zodovedaju. Podobnych veci tam riesili viacero. http://www.teslamotorsclub.com/showt...el-X-FAQ-(wiki)
            Vrso komentoval
            V predchadzajucom prispevku tiez uvadzam, ze sa daju otvarat sucasne. Ci sme sa nerozumeli?
            Cela ta debata vyplyva z prehnanej americkej pravnickej zaluby vsetko v navodoch ci zmluvach rozoberat extremne do detailu a upozornovat na akukolvek hlupost, co sa da vymysliet. Napr. "nedavajjte psa ci dieta do pracky"... Rozoberaju aj zalezitosti, ktore su kazdemu jasne. Dvere na TMX sa nemozu zrazit. Komplikuju to upozornenim, ze pri zatvarani oboch alebo len jednych dveri nie je dobry napad pchat prsty medzi predne a falcon dvere, lebo vysledok bude rovnaky ako na ostatnych autach ked nechate prsty medzi dverami a zabuchnere predne dvere (alebo zatvorite posuvne).
          • 2001
          #20
          TMX ma odkladaci priestor vo dverach a stredovu konzolu uz standardne nie za priplatok ako TMS. Da v buducnosti Tesla do TMS odkladaci priestor do dveri ako ma TMX? Bolo by to fajn. Kliknite na obrázok pre väčšiu verziu
Meno:	tri-veci-ktere-nam-na-sku-chybely-a-xko-je-ma.jpg
Videní:	193
Veľkosť:289,6 KB
            • 2001
            #21
            Automobilka Tesla Motors nově zařadila do nabídky příplatkového vybavení pro Tesla Model X také interiér ze syntetické kůže. Prý na nátlak veganů.
            Nie som sice vegetarian, ale umela koza v aute tak to suhlasim.
            • Karol
              • May 2015
              • 161
              #22
              Test modelu X:
                • Aug 2015
                • 69
                #23
                Konecne dlhsie 40 minutove Review TMX P90DL
                  Toto je dobre video, ten chlapik kecia celych 40 minut.
                #24
                Kratke video montaze falcon dveri na Instagrame Tesly
                20K likes, 442 comments - teslamotors on February 11, 2016: "Model X gets its wings #Tesla #factory #ModelX #cars #electric #suv".
                  • Aug 2015
                  • 69
                  #25
                  Pekne urobene video o detailoch TMX a porovnanie niektorych zaujimavych parametrov TMX a TMS.
                    #26
                    Uputavka na nejaku modnu prehliadku s TMX v hlavnej ulohe - zopar zaberov z montaze a lakovne TMX
                      #27
                      Video modrej TMX vystavenej na autosalone v Zeneve - v nemcine od AutoBildTV
                        #28
                        Test TMX s obytnym privesom 7,3m 1043kg:
                        zrychlenie na 96,6km/h za 5,5 sek
                        dojazd znizeny na cca 75% t.j. na cca 280km pri rychlosti 80 az 88km/h
                        24feet = 7.3m
                        2300lb = 1043kg
                        50ml/h = 80,5km/h
                        55ml/h = 88,8km/h
                        60ml/h = 96,6km/h
                        175ml = 281,6km
                          • 2221
                          #29
                            • Aug 2015
                            • 69
                            #30
                            Preco sa netreba ponahlat s kupou TMX?
                            Pretoze stale este ma TMX dost chyb a toto je prve video, kde su zachytene viacere problemy.
                            Navyse, tento rok zrejme bude upgrade aj na 100kWh baterku a autopilot AP 2.0 , ktory uz bude schopny plne autonomne jazdit. Doporucujem pockat.
                              Urcite ten autopilot 2 bude plne autonomny? Ved hovorili tusim o plnej autonomii az cca o 2 roky.
