lava strana smeroviek mi vyrazne rychlejsie blika ako prava, pri zapnuty vsetkych vystraznych idu obe strany rovnako, vcom je mozno problem?
TM3 LR 2021 rychlo blikajuce smerovky
Veď sa pozri so servisného menu, čo Ti píše, určite je tam nejaká diagnostická hláška.
Ak nevieš ako, tak https://www.youtube.com/watch?v=O2dyoPuT-3g
Na rozdiel od iných áut, diagnostiku nepotrebuješ na väčšinu chýb.[priezvisko]@me.comKomentár
nie, ale vsimol som si ze mi ostala svietit cerveno ikona tazneho a pritom nieje zapojene a aj je vypnuty rezim thania, tyzden dozabu bolo zapojene. rychle blikanie a ikonu som si vsimol az terazKomentár
nasiel som toto v manuale idem pozrie:
If Model 3 is in Trailer Mode or has detected a connection for trailer lights, and the vehicle detects an electrical fault in the trailer turn signals, the turn signals for the affected side(s) will flash faster than normal. If you are finished towing and have disconnected the trailer electrical connector, the turn signals will flash faster than normal and the red trailer indicator will display on the touchscreen until Trailer Mode has been manually disengaged.
Some Autopilot features, as well as rear parking sensor functionality, may not be available when Trailer Mode is enabled. In addition, these features operate differently:
